Hi I am trying to render a simple animation; screw goes from up to down position.
I created two scene in sketchup; one with screw in up position, one with screw in down position. the screws are in their own respected layers, for the up scene, I hide the down position screw, only shows the up position screw. For the down scene, I hid the up positioned screw, show the down positioned screw.
When I render the animation, seems vray only renders the scene I am currently on, if I am on the up scene, vray renders 29 frames of the screws up position scene. the screws does not move one bit in any of the 29 frames.
Set Scene Delay = 0 seconds (in SU Model Info settings)
I think the first 30 frames will be exactly the same due to this delay (1 second = 30 frames) and true animation starts after frame 30.
Or you can start animation rendering at frame 30 (in VR Asset Editor - Animation - Time segment = Frame Range / Start = 30 / End = max value)
BUT screws will not move slowly down anyway. They will suddenly appear at second position from one frame to the next one. You can test some plugins like SU Animate, or MS Physics (for SU2017) if you want to animate components in SketchUp.
Currently for animations we only use the interface that Sketchup exposes. This means that on render/export we export the model as is currently viewed. Then if an animation is present we ask SketchUp for the following information for each frame:
1) camera transform
2) sun transform
There are more native SketchUp animation features we would like to support, including face-me-components, section-planes and entity visibility. We do not however plan on supporting third party plugin animation tools any time soon. They are welcome to interface with us though. We now have a public API they can leverage.
