animation rendering blue result :(
I have just completed an animation pre pass for the IR map. I then chose animation rendering and loaded the first file in, and this is the result I got when rendering. what the hell?
After so much trial and error I am not getting the result I want when using this method for rendering with moving objects.
what is the correct way to complete this process? The tutorial for animating moving objects is flawed and confusing.
Do I load in the first IR map being IRmap0000.vrmap which is about 7mb or do I load in IRmap.vrmap which is 1kb?
When I render the animation even though I have pre calculated the IR map it still completes 4 passes before it renders, why? and is this correct?
Do I keep use camera path for IR checked or unchecked after I have completed the pre pass?
Is Interp frames at 4 better than Interp frames at 2?
Also the IR map was rendered in a render server and the file on the local machine had been closed and re opened, I dot see how but would this have made a difference and caused the IR map to render blue?
You need to specify the file name without the frame numbers; V-Ray will add them automatically. You can check the V-Ray log to see if the correct maps are loaded.
When I render the animation even though I have pre calculated the IR map it still completes 4 passes before it renders, why? and is this correct?There is probably a material with interpolation for glossy reflections/refractions somewhere in the scene.
Do I keep use camera path for IR checked or unchecked after I have completed the pre pass?It should not matter.
Is Interp frames at 4 better than Interp frames at 2?4 will produce a smoother result (will blend 9 irradiance maps), but will be slower.
If you are still having issues, would be best to get us a scene along with several irradiance maps to vray@chaosgroup.com and we’ll check it out.
