I thought Id start a new thread about IR animations with moving objects, as its all I do and Im sure many others will find it useful.
As 1.5 is only in to its second day with us, I have no advice yet!! But I am trying it out over night.
My first questions are do you need to render every frame just with “dont render final image” turned on, and then render the image seq using the IR map? and how many frames should you interpolate between?
Edit:
I have now found out the answer to my questions!
Yes you do render every frame, and it generates an IRmap sequence, and it also doesn’t render the image be default.
You then change the option to animation(render) and find the first IRmap in the seq.
I am testing with different number in interpolations, 2 was not great, and 3 is better.
More soon!
Edit again:
Up to 5 interpolations now, and the render time is getting slower, but image is better! As you might expect. Every interesting to see vray take 11 IRmaps and make one image.
