Making Wine WIP
not sure that understand what you mean ![]()
Should have been in section for the Beta
Similar to
http://www.chaosgroup.com/forums/vbulletin/showthread.php?64689-surf.max
sim stops before 30 frames and won’t continue even though memory is not an issue
frustrating because I’m loving the first 30 frames
well, i’m still awaiting for volunteers for remote debugging because can’t reproduce the problem. i suspect the problem is really serious despite the easy cosmetic solution that hides it. if you wan’t to participate send me your skype
I don’t have skype, but is there a possibility of getting the nightlies? Increasing the field of debuggers might stretch out your debugging curve
ask the support, i think they will give you access
found a solution for http://www.chaosgroup.com/forums/vbulletin/showthread.php?64689-surf.max
Changed Grid?boundary Condition/x to “Jammed-” and the block was gone
