what could the problems depends from?
does the instanced map in different slot of a material create problems to vray as splotches?
Or the output value under bitmap options
Or the color map curve variation under output in bitmap options
wich other problem cause splotches that’s not cropping map and raytrace reflect map or raytrace materials?
Because I have a splotches problems and I don’t understand why the materials (submaterial type with vrlmtlwrapper on top) gives the problem
It’s a model car if I give unique white vray material I get no errors
Incredibles problems those last times I’m a little disperate
excuse my bad english
bye and thanks in advance
