I hava a quick task and shader in the title should be good , really good.
Do U think I should focuse on standard vray mat or go into deep into SSS simulation or so… ???
czaps
czaps
thank You for a help link. Neil Blevins is Guru in CG stuff as everyone knows so I should check at his website first…
thanks Joconnell
czaps
try the natural shaders, too…
best regards
themaxxer
how well do they work with vray - i’ve never tried them…
DZL
i played with the demo a while back…they basically work fine but they tend to be a bit bitchy to tweak for low rendertimes due to their displacement. It´s needed to look good, but it uses max displacement (so in vray it uses the “default displacement” override). Tends to get a bit slow…but looks nice in a lot of cases…some controls seem a tad confusing at times.
Thorsten
I would also recommend you try the DarkTree shaders.
I have done some snow tests with it and the result was really great.
nikki Candelero
Thanks all for help… i’ve solved a problem …maybe it’s not so perfect solution but just accurrate for the time/quality purposes /// I’ve used standard vray material and played with transluency, reflection and fog color , basing on dirty white color as a base wit some help from Neil’s site with procedural noise as a bump. As soon as I’ll finish this staff I’ll put here a small samples what I’ve achieved with this technique. THX
czaps
