Archived Old Bugs
***PLEASE POST ALL BETA 10 BUGS HERE***
Good idea. :slight_smile:
I have here a scene, it always crashes if I use angular mapping type for the BG texture. It happens with any texture I choose, HDR, jpg etc… All other mapping types work.
You’ll notice that when rendering, some buckets remain black and suddenly it renders very quickly some black buckets and then it crashes. It creates a crash dump or something, telling me that this crash dump stuff is a brazil feature.
Here is the scene:
http://www.aversis.be/vrayrhino/bollentest.zip
RCM creates a crash dump on an unhandled exception of some kind.
I’ll see if I can track down the problem.
I’m haveing some problems on getting things to render. Just using the default light or a point light the scenes are dark and the objects are not even being light properly. Basic materials from V-Ray have been applied to the objects and to make sure, V-Ray was completely removed - the plugin folder deleted and reinstalled. I don’t think it’s something that I did, but who knows… these are newly created scenes, no V-Ray options have been changed.
Thanks,
Glen
It started with build 10.
my scenes - http://www.3ddigitalgraphics.com/v\_ray/simple\_scenes.zip
default light
point light 1
point light 10
point light 30
Flamingo
Hi Glen, it is because build 10 incorrectly set the Bright Multiplier to 0 by default in Color Mapping rollout. :wink:
Thanks! It’s been a long week… next time I will pay closer attention to the change log.:sweat_smile:
Glen
Oh! Should we post here bugs from 10.5 ? :slight_smile:
This seems to be fixed in 10.5.
Paul, I guess it is best to start a new 10.5 bugs thread.
I suggest for the sticky bug post, that the first post contain a buglist with numbers. This list could be updated every day. If a bug is fixed it would be marked as “fixed”. If a new beta version is released, we could copy the list to the next new bug post. So every user could get an easy overview about the current bugs.
@Flipside-
Can you please keep testing this angular issue. We are getting bad buckets and crashes once and a while. We are looking into the issue.
@Micha-
We are considering our options for keeping everone up to date with the bug list. For the most part we are trying to take care of this in the Readme file and the announcement posts. The problem is that when bugs are posted they should not be added to the master bug list until they are confirmed bugs. Some bugs that are reported are not bugs. Other reported bugs simply take us time to get to root of the problem and some times V-Ray is not the problem. So it’s rather complicated. We are trying to simplify this. The reason for the sticky with this thread was so that we can consolidate the bug reports. This may not be the best solution either…however, we will try to build on this.
Corey
***PLEASE POST ALL BETA 10.5 PROBLEMS HERE****
The subject says it all :smile:
Corey, the readme bug list is very short, I feel to short. For example I have reported that Vray dosn’t use JPGs with the sufix *.jpeg. Is it fixed?
An official bug list with all bugs could be good. You could mark bugs with following marks “fixed”, “in work”, “no bug” or “not confirmed”.
If you like, I and the other Beta testers could build a new list of current bugs inclusive the old bugs. Everybody could test the old bugs again and report if one is not fixed.
Light Portal: I’m not sure which lightcontrols should not work in portal mode, but the light color show an effect on the portal light.
Example: box with an opening, a light portal placed. GI enable, GI environment enable. Render an image. Change light color to red and use _renderwindow. Good to see here - the color of the light has changed.
Also, the Background environment show a grey seam there the image is closed.
Micha,
Some things are indeed bugs. Other things however are items that need to be placed on the wishlist as they are indeed missing from V-Ray for Rhino.
Feel free to make two new consolidated lists. It won’t hurt.
Corey
Some increments sould be adjusted:
- increment of all map multiplier are 1, but 0.05 could be better
- increment of bright/dark multiplier is 1, but 0.05 could be better
- increment of the LC subdivs is 1, but 100 could be better
Also, some times if I start a rendering and my small RAM (750MB) makes that Vray starts very slow and I like to stop it and close the frame buffer, the whole Rhino crash complete. This problem I have seen sometimes in all of the last builds.
Micha,
With regards to your crash, is this after you have accepted the evaluation mode?
Corey
Hello Newsgroup,
Micha wrote:
>Also, some times if I start a rendering and my small RAM (750MB) makes >that Vray starts very slow and I like to stop it and close the frame buffer, the >whole Rhino crash complete. This problem I have seen sometimes in all of >the last builds.
I am experiencing this too, although i did not notice it in the earlier builds. Right now I am not able to reproduce it. It happened to me a few times while doing stuff in another application at the same time. Rhino crashes, no warning, no bugscreen, it just vanished…
i will try to recreate it somehow
best regards
Andy
Yes, the Vray has load all maps and open the renderpreview. At this point, Vray slow down and if I close the renderwindow - crash. The crash point could be after the start of LC calculation. But I’m not sure.
Can you send us a scene that you can reproduce this on.
Please.
Corey
Sorry, I can not repeat it, but I will observe it. :wink:
Other problem: the reflection map dosn’t show any effect.
Corey, what do you think, when will work the texture mapping (tiling) tool? If it will be in the next days I would render some final images later.
-Micha
