HI All
When I Use the Option “Use Light cache for Glossy Rays” in the Light cache there is a lot of artefact in the render in GI Pass apparently, is there something to do to cancel this.
Thanks for the Helping
You could try to use the “Fixed” filter type for the light cache, and/or turn off the “Store direct light” option.
Thanks it works but the render seems to be very slower, probably due to bad parameter configuration
it better works if i don’t use the light cache for glossy rays
thanks for your answer.
