Artifacts when motion blur is enabled
Just installed the latest version with motion blur and here’s what I get with motion blur disabled:
Then when I enable motion blur I get this:
Happens when RT is set for production and active shade. Same thing happens if I use OpenCL or CUDA options. The only time it works correctly (no artifacts) is when I use CPU mode.
GPU hardware:
Quadro 6000
Tesla c2075 x2
GPU Drivers: 296.70
I’ve verified the results on two different scenes and after a fresh restart of the workstation.
Thoughts?
Hm, works fine for me in a similar scene (see attachment). Can you get me some parts of the scene so that I can check what’s going on?
Actually, before we get to the scene, do you have a dome light in there?
Yes I do have a domelight with a HDR assigned (VRayHDR map). Is there a different method I should use?
That’s the right method, but there’s a bug with the dome light and motion blur. Will upload the fix on the site tomorrow.
Roger that, thanks for the quick reply!
So this should be fixed now if you re-download the installation (V-Ray RT version should be 2.30.02).
That indeed resolved the problem. Thanks.
