Artifacts
Here is a Sanctuary I’m working on and can’t seem to shake the artifacts at the base of the wood pews. They seem to have migrated form the top of the pews to the base. See attached. Here are my settings.
640X480
Secondary Ray Bias: .001
IR 1.0
LC 1.0
Adap. Sub. 0 min 2 max .1 threshold
Catmul Rom
IRR Map-medium 40/20
Least Square/overlapping
QMC Sampler .85/.003/16/1.0
Maxtree 60
min leaf 0
face/level .5
Light Cache 500/.05/screen scale/4 passes/8 interp. samples/nearest filter
31 lights all have 125 diffuse subdivision
Hi
try Adaptive AA @ 2 ~6
QMC Sampler .8/.003/16/2.0
face/level 1.0
are your lights stored with the irradiance map? if so uncheck that and reduce subdivs depending on the lights size.
Also you may want to reset your lightcache to roughly these settings:
1000 subdivs
sample size to standard 0.02
uncheck store direct light.
pre filter to 100 or there abouts
and i always use a fixed filter.
Natty :wink:
Is there any glossy reflection on the wood material?
Yes, Vlado. The wood has a 20% reflecttion with .8 glossiness, 16 sub. div.
and a max depth of 8.
In that case, instead of keeping the light subdivs so high, you can try to increase the glossy subdivs for materials; also depth 8 for reflections is too much in that case 2 or 3 should be ok.
Thanks, will try.
Is there a rule of thumb which we can use to determine the adequate subdiv value?
no … larger the light, the more subdivs required because the light is covering more area.. experimentation is the key.
