Asset editor not working
My Asset editor stopped working. It looks empty, but allows me to create new materials. It won’t let me go into the settings.
The frame buffer seems to be working normally, if I click render on the toolbar it will render with all materials and lights, but the asset editor doesn’t register anything.
I have recently updated to Vray 6 and Sketchup 2023.
I have already uninstalled and reinstalled Vray.
I have already tried other files and an empty scene. It still didn’t work.
I have also tried on a different computer.
I have already submitted a ticket but haven’t received a solution.
Has this happened to anyone else? I don’t know what else to to and the program is unusable without the asset editor!
Thanks!
Hello carolina_freitas,
We have received the ticket and tested the scene you shared. Unfortunately, we do not reproduce the issue with a blank Asset Editor on our side.
From what I can see there has been some further development in the case; You have shared that a reinstallation of both SketchUp and V-Ray seemed to have temporarily solved the issue on your side (on this and another device) until the next day.
We would like to arrange a TeamViewer session so that we can investigate locally, as my colleague suggested in a ticket. He will provide further instructions on how to proceed.
We will also make sure to update this forum post when we have any information or solutions.
Any solution? i have the same problem, I was saving a model in sketchup and it closed everything suddenly. After re-enabling the file already Asset Editor does not work. I reinstalled Vray 2024 and zero change.​
Hello, Oliwia,
Can you please try the following steps:
- Open SketchUp → Extensions → Developer → Ruby Console
- Paste this text and press enter: VRay::NeUI::SERVICE.refresh_ui
Let me know if that solves the issue on your side!
Thank you for your reply Diana, unfortunately zero change. I added a new ticket with errors. I will paste them below.
Error [V-Ray Asset Editor] TypeError: Cannot read properties of undefined (reading ‘class’)
at file:///Applications/ChaosGroup/V-Ray/V-Ray%20for%20SketchUp/extension/vrayneui/vrayneui.app/Contents/Resources/app-arm64.asar/frontend/asset-editor.bundle.js:154:436810
at file:///Applications/ChaosGroup/V-Ray/V-Ray%20for%20SketchUp/extension/vrayneui/vrayneui.app/Contents/Resources/app-arm64.asar/frontend/asset-editor.bundle.js:154:437022
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async h (file:///Applications/ChaosGroup/V-Ray/V-Ray%20for%20SketchUp/extension/vrayneui/vrayneui.app/Contents/Resources/app-arm64.asar/frontend/asset-editor.bundle.js:177:3158223)
at async file:///Applications/ChaosGroup/V-Ray/V-Ray%20for%20SketchUp/extension/vrayneui/vrayneui.app/Contents/Resources/app-arm64.asar/frontend/asset-editor.bundle.js:168:169058
at async E (file:///Applications/ChaosGroup/V-Ray/V-Ray%20for%20SketchUp/extension/vrayneui/vrayneui.app/Contents/Resources/app-arm64.asar/frontend/asset-editor.bundle.js:177:3176525)
at async a (file:///Applications/ChaosGroup/V-Ray/V-Ray%20for%20SketchUp/extension/vrayneui/vrayneui.app/Contents/Resources/app-arm64.asar/frontend/asset-editor.bundle.js:21:4880)
at async Object.t.runInTransaction (file:///Applications/ChaosGroup/V-Ray/V-Ray%20for%20SketchUp/extension/vrayneui/vrayneui.app/Contents/Resources/app-arm64.asar/frontend/asset-editor.bundle.js:37:57635)
at async e.<anonymous> (file:///Applications/ChaosGroup/V-Ray/V-Ray%20for%20SketchUp/extension/vrayneui/vrayneui.app/Contents/Resources/app-arm64.asar/frontend/asset-editor.bundle.js:168:193915)
at async e._runTask (file:///Applications/ChaosGroup/V-Ray/V-Ray%20for%20SketchUp/extension/vrayneui/vrayneui.app/Contents/Resources/app-arm64.asar/frontend/asset-editor.bundle.js:37:156393) Promise {
<rejected> TypeError: Cannot read properties of undefined (reading ‘class’)
Thank you for the information, Oliwia!
I have forwarded your ticket number 306983 to our Tech Support team, who will contact you once they have more information.
Thank you for your patience and understanding.
