Yes, I will runt 3DMark and see if the gpu performs as it should.
Starting to iron out some problems, but still some left before I can use the workstation without worrying ![]()
The graphics card benchmark worked without any problems.
I“m almost out of ideas regarding these problems so perhaps they will work themselves out ![]()
What about passmark ? Cinebench 11.5 and 15 ? If those will produce results as expected than I guess youāre fine almost :- )
I“ve tried them but I don“t know if they produce the correct result ![]()
However I got an answer from Asus and they say:
1: your PSU does not deliver correct voltage (even if new)
2: your wall socket is giving out bad power, meaning the power curve is bad and causes brownout or deformed pulses, this can cause instability in the power grid.
So Ć gonna try switching to my old computers power supply and the if that changes or return the new one to the reseller.
Hopefully after this everything will work ![]()
Also the Samsung 850 pro seems good! Will be interesting to try the āRapid modeā and see if it makes any difference.
I found out that one of the beeps was regarding my graphics card. Apparently BIOS doesn“t understand what it is.
In BIOS the only way to fix that was to switch video from āLegacyā to āUEFIā.
With that change the system became extremely slow and weird. Loaded Windows in like 0.5 sec but then the screens went to sleep.
Seems weird that this new board doesn“t fully support new graphics cards.
This board is slow and seem to have some problems.
IĀ“d wouldnĀ“t recommend anyone this motherboard, it doesnĀ“t feel finished and more rushed for releaseā¦
Do you have the latest Motherboard version? Just check if they have any hotfix for that problem. It happen the same thing with a HDD I have.
Yes, latest BIOS is installed, or did you mean something else?
The overclocking feature of this board doesn“t seem to work either haha!
Anyway, everything is working (with the beeps) so that“s good ![]()
I meant some hotfix update. Also, check the graphics card website and see if they are aware of the problem.
I see! No, no hotfix that I have found at least, I donĀ“t think Asus is aware of the problemsā¦
As far as I understand it is Asus who have to update the motherboard/bios to recognize the graphics card? Or am I thinking wrong here?
I got everything working, and everything seem stable so I probably leave the workstation as it is and call these problems solved ![]()
Thank you for trying to help ![]()
It really depends to be honest. For example, my motherboard wasnāt recognizing the Samsung HDD. I checked the Motherboardās website and the only thing available was some minor hotfixs. After some search, I went to Samsungās website and found a firmware update specifically for my issue. So, sometimes it pays off checking both ends and keep reporting the issue to both.
I understand, thanks for the tip. I will check Gigabytes website and see if I find anything, thanks! ![]()
