Backburner and distributed rendering
Hi!
I have vray 3.60.04 3dsmax 2017
I decided to use vray rt for rendering.
There are 2 render nodes and 1 workstation.
i’m trying to send renders to nodes via backburner.
I selected distributed rendering, added servers.
Render node which backburner running starts the job but distributed rendering doesn’t start.
I’ve tested distributed rendering from workstation and everything is fine.
Please help.
I assume you have set the distributed render settings on your workstation.
The settings are saved to a file which you have to transfer manually when using backburner. You have to copy the following file from your workstation to the node, that is distributing the render.
C:\Users\Yourusername\AppData\Local\Autodesk\3dsMax\2018- 64bit\ENU\en-US\plugcfg\vrayrt_dr.cfg. Copy the file to the exactly same location on the node.
If you are still experiencing any issues, please contact us at support@chaosgroup.com, or post here in the forums.
Thank you so much.
