batch render - empty black fames
Hi Guys,
I am trying a batch render atm, but I am getting no love. Render fine in VFB for single frames while tuning, but blank in batch. Render-able Camera seems configured correctly, there is no real error aside from
!vrayOnCameraPhysicalOn 0
Which is confusing as the render-able camera definitely has the physical attributes enabled and working.
1/12/2012
Starting "C:\Program Files\Autodesk\Maya2010\bin\mayabatch.exe"
mental ray for Maya 2010
mental ray: version 3.7.53.5, Jun 17 2009, revision 88216
[2012/Jan/12|20:51:40] V-Ray: V-Ray for Maya version 2.00.04 from Sep 14 2011, 12:25:32
[2012/Jan/12|20:51:40] V-Ray: V-Ray core version is 2.00.01
File read in 0 seconds.
Result: M:/Assignments/Term 5/Assignment 01/MAYA FILES/scenes/RENDER_v052__1128.mb
V-Ray: Starting render
[2012/Jan/12|20:51:47] V-Ray: Loading plugins from "C:\Program Files\Autodesk\Maya2010/vray/vrayplugins/vray_*.dll"
[2012/Jan/12|20:51:47] V-Ray: 103 plugin(s) loaded successfully
[2012/Jan/12|20:51:47] V-Ray: Finished loading plugins.
[2012/Jan/12|20:51:47] V-Ray: Exporting scene to V-Ray.
[2012/Jan/12|20:51:48] V-Ray: Parsing light links time  0h  0m  0.0s (0.0 s)
[2012/Jan/12|20:51:48] V-Ray: Translating scene geometry for V-Ray
[2012/Jan/12|20:51:48] V-Ray warning: Unsupported texture VRayMtl
Warning: Unsupported texture VRayMtl
[2012/Jan/12|20:51:48] V-Ray:  (Estimated time remaining:  0h  0m  0.3s): 18 % completed
[2012/Jan/12|20:51:48] V-Ray: Total time translating scene for V-Ray  0h  0m  0.4s (0.4 s)
[2012/Jan/12|20:51:48] V-Ray: Rendering.
[2012/Jan/12|20:51:48] V-Ray: Pre-render export.
[2012/Jan/12|20:51:48] V-Ray: Pre-render export done.
[2012/Jan/12|20:51:48] V-Ray: Rendering frames.
[2012/Jan/12|20:51:48] V-Ray: Updating frame at time 0.75
[2012/Jan/12|20:51:48] V-Ray:  (Estimated time remaining:  0h  0m  0.1s): 56 % completed
[2012/Jan/12|20:51:48] V-Ray:  (Estimated time remaining:  0h  0m  0.1s): 70 % completed
[2012/Jan/12|20:51:49] V-Ray:  (Estimated time remaining:  0h  0m  0.2s): 81 % completed
[2012/Jan/12|20:51:49] V-Ray: Total time updating frame  0h  0m  1.1s (1.1 s)
[2012/Jan/12|20:51:49] V-Ray: Updating frame at time 1.00
[2012/Jan/12|20:51:49] V-Ray:  (Estimated time remaining:  0h  0m  0.1s): 37 % completed
[2012/Jan/12|20:51:49] V-Ray: Total time updating frame  0h  0m  0.1s (0.1 s)
[2012/Jan/12|20:51:49] V-Ray: Updating frame at time 1.25
[2012/Jan/12|20:51:49] V-Ray:  (Estimated time remaining:  0h  0m  0.1s): 70 % completed
[2012/Jan/12|20:51:50] V-Ray:  (Estimated time remaining:  0h  0m  0.2s): 81 % completed
[2012/Jan/12|20:51:50] V-Ray: Total time updating frame  0h  0m  1.1s (1.1 s)
etc…
Any nudge in the right direction will be helpful :)!
Thanks, Chris
just had a problem like that
posted here
http://www.chaosgroup.com/forums/vbulletin/showthread.php?66871-render-selected-objects-check-box-breaks-batch-render
you didn’t say anything about that button, but sometimes people use it to test buffer frames quickly so i figured i’ld post a reply
Can you post some more lines from the log (specifically where it says the number of triangles in the scene)?
Hi Guys,
Thank-you for the replies. I have just come back to this scene with fresh eyes, and have worked out that the issues was with “zooShots”, a script from multi camera shot setup. The changes/attributes were not being passed correctly by the zooShots node in Maya batch or when exporting for standalone. Baking all animated/connected attributes on the camera and deleting the shots node fixed the issue. It is slightly annoying as this is a one way step; I will look at the script at a later date and see whether I can find a better fix.
Jermy, good to know! I use that all the time.
Vlado, you are the busiest guy here, thanks for the reply but in this case it was user error (of sorts),
Kind Regards
Chris Dardis
