Is the correct way to batch render a single scene with some render layers done by going to to the Render Menu and select Batch Render?
I try this and all my renders are of the first frame of each layer!
I’ve selected Standard in the Vray Animation area and set my frames. I’ve also tried it with checking/unchecking the Don’t save image (ignored in batch mode) and Render animation only in batch mode.
Please help!
Rendering works fine by just hitting the teapot icon in the VFB but I would like to also use batch render.
you don’t need to use maya batch render from ui, if you want to render animation. You can check in your render view - render all layers, then go to common tab and enable animation specify your frame range make sure render animation in batch mode only is off and simply hit maya’s render current frame button, vray then will render the entire animation for each enabled render layer.
I’ve been doing this via the VFB. Should I be doing it using Maya’s Render View?
Also, I’ve been rendering on scenes on co-workers computers (we don’t have a network render system setup yet) and random JPEG/PNG sequences are corrupted when I bring them into After Effects. I was using TIFF files but they were too large for our storage so I went to PNG and then JPEG (we are not doing any complex compositing so I don’t need 32 bit EXR files or files like that).
Could it be that Maya/Vray just don’t like outputting JPEG/PNG files?
Batch rendering from the Rendering menu should work just fine. Are you getting any errors in the output window or the script editor ? Can you also check for errors in the mayaRenderLog.txt (usually in Documents/maya)? You can just delete this file, then do a batch render and maya will create it again, so it will contain a log only for the last render.
And another thing - can you try and do a command-line batch render and see if that fails too?
On windows, you should open a command prompt (type “cmd” in the start menu’s search) and type the full path to Render.exe, usually in C:\Program Files\Autodesk\Maya<version>\bin\Render.exe -r vray <path to scene>.
You can either use some sort of render management (backburner, deadline, etc), or make a windows batch script that renders all .ma files within a folder, or simply open a text editor, and on type in the same cmd line I mentioned for every scene, then save as .bat. In this case you’ll have, say:
C:\…\render.exe -r vray <scene1>.ma
C:\…\render.exe -r vray <scene2>.ma
