batch render / lightmix setup
If it’s working, then it’s correct. :smiley:
You could also try this, but it’s a more destructive workflow:
  1. Set up your scene with default light settings (not affected by LightMix in any way - so for example white lights, not colored)
  2. Save this as a scene state so that you can always return to lights with default non-affected settings
  3. Set up your LightMix variant A (for example daylight with dim lights)
  4. Use the “>Scene” button to bake LightMix settings into the scene lights
  5. Save this as scene state A
  6. Load the scene state with default lights
  7. Set up a different LightMix variant B (for example nighttime with strong lights)
    :cool_button: Save this as scene state B
    Then you can batch render different cameras with different scene states and each scene state contains different light setup.
Please do share your results. I am interested how it works. :smiley:
