How to Batch render 10 cameras each one have different light mix settings?
I’m looking for a script that stores light values in a light mix of corona renderer in the following method:
Let’s say I have 10 cameras, customer asks for making draft render for all these 10 before the final submit, should I save 10 light mix files, or there is another method?
Thank you
I would probably batch render them all out as CXR’s and load in your individual lightmix config files in the CIE.
check this out it may come in handy
[https://forum.corona-renderer.com/ Corona Batch Image Editor GUI⁣ ](https://forum.corona-renderer.com/ Corona Batch Image Editor GUI⁣ )
Check out Pulze. It’s amazing and has totally changed my workflow. It supports Lightmix although I haven’t used that portion yet. But it would be perfect for this type of scenario and client. It’s basically what scene states could have been
Pulze! I knew there was a plugin i couldnt remember the name!
Yes! I recommend their render manager too. The two plugins are nicely integrated. I just started using both of them a month ago for a big animation project that came in the door and it has saved my proverbial bacon…
Like Pulze you can make use of RP Manager http://rpmanager.com/. It works fine in combination with Deadline.
Thank you very much, It seems this is what I want, but the download link was not working, any idea?
It seems this script has more advantages than I need, all that I need is a script that uses a separate .config file for each camera.
This link didn’t work.
