batch rendering....???? again problem...
please somebody tell me is there any option for batch rendering… means set 3 or 4 scenes and render one by one continuously !!! thank u…
Re: batch rendering…???
It sounds complicated (and it’s far from intuitive), but it’s actually very simple to setup and works extremely well.
Create your scenes in SU, then (still in SU) go to View>Animation>Settings, tick the “Enable Scene Transitions” box and set it as 1 second transition. Set the “Scene Delay” as zero.
In the V-Ray Render Options open the “Output” panel, under “Render Output” tick the “Save File” box and (using the … button) browse to the folder you want to save the images to (don’t forget to select the image format from the drop down menu). Then under “Animation” tick the “On” box, select “Custom” and set a framerate of 1.
When you click the “render” button VfSU will, one-by-one, render and save all your SU scenes to the folder you selected so you can leave it running overnight or work on another project.
Note however, that it will not take into account the visibility of hidden or unhidden geometry, layers and face-me components will be fixed at the poistion they were facing on the first scene.
Regards,
Jackson
thank u very much 4 ur comments…
i followed all the steps as u said…but from the 2 scenes i get only 1 is repeatedly saved in the folder selected, 2nd scene is not rendered!!!do i have 2 notice any other specification…anything in the scene manger… any otter option in v-ray …please help me…
Re: batch rendering…??? again problem…
Sorry, I should have said, you have to add an extra scene because of a bug in VfSU. Just copy your last scene so there’s two the same at the end and it should work perfectly.
ok… right…i got ..it.. i tried and it work perfectly…thank you once again for your support… ;D
too bad about the face me being fixed across all scenes…
