Hey all.
I still haven’t got time to try this but a friend told me the batch render wasn’t working with Corona, is this true? And if so, is there any workaround for this to work so I can make multiple camera renders overnight?
Thanks.
Hey all.
Thanks.
Batch Rendering works fine with Corona
But best solution I’ve found is “Power Render Terminate” script
thanks,
but I still got an issue about DOF, because I try each camera in different DOF camera distance, DOF is only base in the render setting in each frame ( I mean only one frame) for example :
In one scene I got 3 different camera in different DOF setting camera_01 F stop in 5.6, camera_02 F stop in 2.8 and camera_03 f stop in 1.4, how can we make a setting on it? override camera setting?
regards,
N
This may be a little late, and I´m not sure it would work because I haven´t tested myself, but it MIGHT work (your DOF problem) it you use batch render and save a scene state for each camera with different DOF settings?
