Batch rendering not saving renders
I’ve been using batch rendering for several years with no problem, but today, after updating to version 7.20.04 the images start rendering but they are not saving in the location I set in the batch render menu.
The log says: Warning: Render elements can be saved only through the VFB outputs.
Is this intended with this new version or am I doing something wrong?
EDIT: I set the output to desktop and everything worked fine. I’m guessing the problem was the original output path had accents in one of the folders.
Hi, when you used batch rendering, it save rgb image only.
