I know I can set the bake down the texture for the viewport with a way higher res than 64x64!
But I think we should have it working by default,
file node using v-ray , should be a supported texture type.
Feel free to ask Autodesk to improve their Viewport 2.0 API and documentation… oh and to stop changing it completely from one release to the next.
I will do it on the beta forum!
Thanks Vlado.
I will follow you in the beta forum because i am also interested by this feature ![]()
obviously as a workaround you can assign lamberts and phongs then use material override which works with important textures that need to be looked at in the vp.
Yes; it’s good we added those overrides, isn’t it
Even though we didn’t do it for this purpose originally…
