Bitmaps not shown in viewport - CoronaDistance
Bitmaps do not show up on the viewport when the bitmap nodes are wired to CoronaDistance. I tried toggling the “Show maps on viewport” icon and it does not do anything. But if I bypass CoronaDistance to the Diffuse slot in CoronaLegacyMtl or CoronaPhysicalMtl it works. Something is wrong here. it used to work.
Corona 10
3dsmax 2024
RTX 4090
I was able to reproduce this issue. This is now logged in our system to be further reviewed by our devs.
(Internal ID=1171510599)
Just a kind update: It seems like if you set your viewport from standard to High Quality then it works fine. You can use that as a workaround for now meanwhile, it’s getting looked at by our devs.
