Hi, perhaps I’m missing it, but is there a way to specify a blend mode in the Blend material? For example, I’d like to set a layer to Multiply. If not, is there another method to achieve the same effect? I’m building a concrete material and adding some defects/stains (splatter, etc.) on top.
I’m looking for a material like this: V-Ray for Maya
Hi @colinpkelly
There is no such option in the Blend material, you can control the blend amount between the base and coat materials.
Try doing this on texture level - by using some of our Utility Textures (maybe some of the mix textures), you might be able to achieve the desired effect.
I’ve prepared a sample recording for you to check: http://ftp.chaosgroup.com/support/sc…5_15-42-53.mp4
To read more about the Utility Textures, please visit: https://docs.chaosgroup.com/display/…ility+Textures
oh yes, that should work! i’ll try that thanks.
