Since updating my Enscape to version 4.22.0 it has been making my textures in the render view look extremely blurry. This isn’t even the worst example, in some files the textures are completely unreadable.
I have tried adjusting some settings with the auto resolution and auto upsampling as well as depth of field but it has not changed. It also seems to adjust clarity as I move around the file and then go back to being blurry.
This is happening in all files with textures mapped for me since updating and they stay blurry when rendered. Files that I once had perfectly clear textures mapped are now completely blurred in render.
Any advice on how to potentially remedy this would be appreciated!
Hi @Kayla_Horne
thanks for informing us about this as well. This issue has to be handled on an individual case basis depending on the content of the log files.
Please open a case with us via the support button and make sure that the checkbox to include log files is active. We will then be in touch with you.
Thanks in advance.
Have you figured out a fix for this? The same thing is happening to me right now and I need to get these designs finished ASAP
Less a “fix” and more a work around for the time being. I had tried updating sketchup to see if that would help the blurry renders but it hadnt so I went back to sketchup version 2026 and offloaded enscape 4.22.0. I downloaded the enscape LTS version and that seems to work again for some reason. Im not sure what the issue with 4.22 was.
I can confirm this issue as well. I went back to 4.21 and zero issues.
Its ok to pay people in the real world to find the bugs before release. It shouldnt be us paying you to find bugs like this.
Hi Kayla, Josh and Ryan,
as mentioned before, please open individual cases via the support button. The fix is in development and progressing well.
A valid workaround is available but depends on the individual setup. So please, again, open a case with us each and we’ll be happy to provide the workaround for the time being until the fix is released.
Thank you for your understanding that this has to be handled on an individual basis.
