BMD Fusion + Cryptomatte + exr multipart.
i’ve got a problem:
In black magic fusion cryptomatte is supported via a free script.
It only works on exr’s where the exr multipart option is checked off in the option RE element.
But Im rendering 16x2k cubemaps and have to do quite some compositing.
Not even my computer with a 4090 is any joy to work with in fusion if that option is checked off.
I tryed to use the save seperate render channels option in the VFB secion to try and use the cryptomatte channels from that as I believe it uses the 3ds max exr saver (at least thats wht the dialoge looks like)
But that doesen’t seem to work in fusion either.
Did anyone find a solution for that?
Have you tried the “Save Cryptomattes separately” option in the V-Ray Raw image file browse window? It will save a separate .exr with only the cryptomattes. Maybe that can help.
Regarding the Separate render channels - Cryptomatte doesn’t work when saved through that output.
My god!
That actually works!
You just soved something I’ve been bummed out about for at least 5 years. It forced me to setup multimattes in soo many projects where I would have loved to use cryptomatte.
Thank you soo much.
