Boom and Glare before LUT's
would it be possible to add the Bloom and Glare before you apply the different LUT’s ?
since the luts compress to a 0-1 value, it seems more difficult to apply the bloom and glare only to the very bright spots (with the Threshold), if i am not mistaken.
Yes, the LUT changes the intensity of pixel values and it affects the appearance of the B&G effect. For example, there is the threshold parameter which determines the minimum brightness necessary to apply the effect, when the LUT changes the brightness of a pixel, it can change the decision whether the B&G is applied or not.
We have logged this as a feature request to see if we can improve it in the future.
(Internal ID=1298218878)
