bug - get resolution from max uncheck
when get resolution from max is unchecked and new resolution is input from vray frame buffer and dr, the resolution is not taken into account, and vray frame buffer although expanded to specified resolution has the actual image on the side with the previous max resolution instead.
Yep, I believe this is fixed in newer builds.
