Backburner 2013 and get resolution from max
Hi!
I have an issue where if I submit a job to backburner 2013 from max 2013 and vray 2.30.01 and uncheck “get resolution from max”, backburner still use the resolution set in max. This also becomes a problem when using the VRayStereoscopic. The image is then rendered at double width but saved with the width set in max. I don’t know if this a issue that I should report to autodesk or chaosgroup.
Thanks!
/Andy
Thanks for the pointer, will check it out, but there may be little that we can do about it.
Thanks for the reply!
That’s what i thought. This will be the 3th bug-report I send to Autodesk about backburner 2013. The first two will be fixed in the next service pack.
Thanks again!
I just noticed that it is not just in Backburner. The problem is there when I render from Max as well. So I will wait to nag at Autodesk until you have tested it
Can you get me more specific reproduction steps or a scene? This works fine for me on a simple test when rendering inside 3ds Max.
Here is a simple file. The framebuffer is correct but check the saved file.
test.zip (22.7 KB)
Thanks, will look into it. In the meantime, you can use the “Split render elements” option in the V-Ray VFB settings to write the final images.
I’m trying that and it seams to work. Have you had time to look into it? I don’t mean to rush you, but I have been in contact with Autodesk about a few other bugs and Product Update 6 is soon to be released and if this is a Autodesk problem I would like to send it to them as soon as possible.
Have a great day!
Hi!
Have you had some time to look into it?
We are still working on that.
