Bug: Only one domelight per scene renders correctly
when adding more than one domelight to a scene, only the first domelight renders correctly. All other domelights are very dark. This can be best observed when adding the domelights to light select render elements.
Light evaluation has no influence on this behaviour.
“Use transform” in the VRayPlaceEnvTex node and moving one domelight has no influence on this either.
I have attached a Maya scene that shows this bug.
VRay 4.12.01
Maya 2018.6
Cheers, Florian
domelight_error.zip (4.8 KB)
This is on my “to do” list to resolve, but you are correct that at the moment the result is not corrects. I will get to this soon.
