Once you have set your camera, applied “automatic vertical” very often it changes itself … as on example, a new camera created, I apply “automatic vertical”, the camera reacts anyhow, impossible to the to regulate, to force to use a physical camera.
thank you
Yanosh
BTW for the video, it uses Adobe Flash, which many computers (including mine) no longer have installed any more as support was removed from browsers due to security concerns. Could be good to use another format to ensure everyone can take a look.
There was an issue with “wandering” cameras but that was fixed in hotfix 2 (just to be sure on that, did you check it is hotfix 2 that is installed? Also, would be interested from a testing point of view on whether this happens with dailies)
For screen capture, the free OBS (open broadcaster studio) is great and saves as mp4, which can be uploaded for sharing Would be a problem if a video showing a bug could not be viewed by the developers for example, if something like Flash was used.
I am not sure what you mean about download to the site - do you mean upload to the forum, or upload via our private uploader (at https://corona-renderer.com/upload)?
I mean upload to the forum, excuse my bad english…
anyway… wetransfer is uploading it. 1 GO, still half an hour… internet connexion is very slow in my office …
Almost every scene I open from someone else is infected with animation layers. Merging another “infected” file will increase the count every time and they can be found in many assets from various sources - even “reliable” ones.
Hello Frood,
thank you very much for your help and for your tricks…!!
I’ got a serious probrel with scale…, I don’t know where from.
at the beginning of the work of this scene the scale was good …
as I still learn to use 3DS (it’s only been a few months I started) I do not master everything.
I discovered the use of “grid” I tested some settings, maybe this is the cause …
in the end, as long as I import an element into my scene, it is found on a huge scale …!!!
Hmm, you mean when merging something? Maybe check the following:
Customize → Units setup… → System Unit Setup → Checkbox “Respect System Units in Files”, it should be active. But I think this is the default anyway, so it’s only a guess.
