Hello.
When i open a scene in 3ds Max with a corona cam with automatic vertical tilt option activated, i always have to deactivate and reactivate this option in order to see the effect in the viewport.
The vertical correction works fine when rendering, even if i dont do this procedure… Seems to be only afecting the viewport.
Thanks in advance.
hello
I have the same problem too. And even with the horizontal and vertical shift. I already had that with the previous version of Corona.
It does not matter, but sometimes it’s annoying !
In which version of Corona was the original scene made, and in which version was it opened?
Can you send us any scene like this? (even very simple) Here is the uploader: Chaos
Don’t forget to tell us what is the file name!
Thanks in advance!
Thanks for the reply.
The scene was created if im not in mistake with Corona 3.0 and at the present moment, i’m using 3.1 version.
The file with the issue has been uploaded.
I’ve noticed this as well with Corona 3.0. Let me know if you want my file as well. Hopefully you can figure out what the solution would be.
