I have a scene I rendered in corona 9 on max 2024. It had lights with animated image sequence as projection. WHen I tried to render this scene now in the current version of Corona the image sequences stops after a few frames and just freeze on the frames. I tried rendering the same lights through Scanline render and it works fine, so this is a new bug in Corona. Is this something you could look into?
Hi @joachimbarrum_gmail.com , this is already fixed and will be included in Corona 16 RC2 and the final release. The current workaround is:
- Open the Development / Experimental Stuff rollout - https://support.chaos.com/hc/en-us/articles/4528523195537-How-to-enable-the-Development-Experimental-stuff-rollout-in-Corona-for-3ds-Max
- Disable Fast Animation Parsing
