i found a Bug with the new tone mapping and connecition to cameras.
here and there when using IPR and switching between default cam and saved scene cameras, the tone mapping in the saved scene camera gets lost.
so the default obviously has a default tone mapping, my scene cameras special tone mapping used. when i switch to default cam and back to scene cam, the scene cam here and there has also only the default settings.
i hope it is understandable what i mean?
i had this happen in several scenes, but it only happens here and there, not regularly.
hi
as it happens only here and there i am not sure, as i cant capture myself during work all time:)
it is always and only if i use the IPR and switch back and forth between c4d cameras and the default camera. it works many time but after 1-h work sometimes the camera then keeps the tone mapping of the default cam. my feeling is it happens when the model is bigger and i switch faster between default and normal cameras.
