Hi hopefully someone can help me out. I’m having a problem adding a bump map to a vray linked material. Once i add the map and render the scene the material becomes very small in scale and no does appear to the bump map on it while both the UV scales are set to “1” respectively. any help would be helpful thanks
Re: Bump map Problems
See my answers (especially the second) in this thread for the diagnosis and solution:
Hope this helps,
Jackson
i read your responses and nothing still seams to work. I have been able to to have the bump map work when creating a new vray material but not a vray linked material the scale on the rendering of the bump map is off.
