Bump texture and displacement questions
Sorry to bother again, but I’m stuck on a stupid problem.
How come I can only set bump throught a bitmap? each time I try to use anything else (a grid, a checker, a noise etc…) it has no effect on the rendering.
Is that a limit of my testing version or am I setting something wrong?
Another question is about displacement: I’ve seen really cool .mat for v-ray for max made with no texture but just a displacement setting, like grass or fur: is this something different from bump, and is it possible to have the same thing on VRfR?
Lila
Currently only the bitmap texture supports bump-mapping. Also displacement is not available to us at this time either. We are working toward resolving both those issues - but the displacement side is out of our hands entirely unfortunately.
beside this we can do both using other ways.
what do you want to achieve on your project ?
we surely can help.
Jp
Thanks for your kind answers!
I’m working to make ceramic tiles.
This is what I did (with a bump bitmap).
As you can imagine those are the esiest to be done! :shock:
ok but what is the harder stuff you need to do for now ?
A carpet… :?
do you have a reference picture ?
I would like to make something like this, but I cannot imagine how to do it without displacement..
It seems like this topic has been covered elsewhere today (JP?), but you might be able to modify Micha’s Grass concept with a different image to create a carpet like that.
Might be a place to start.
Thanks for the answer… I really do need to have a registered copy since most intresting topic are unavailable to me :frowning:
I knew that she didn’t have access to it, but I wanted to wait to see what she needed first before copy pasting info… :slight_smile:
Maybe I should simply wait for Micha to update Material tutorial :wink: (it’s him, isn’t it?)
buona idea !
come cosi non dovo fare tutti le lavoro di taliare et incollare gli informazione :wink:
Do non registered VFR forum members have access to the Gallery Section? I forget, if so…
This is what I was refering to.
how do i have to understand that? :?: :roll: :?:
I’m referring to the information Jean-Paul Paloux provided in your thread, in regards to Micha’s grass concept.
However; I didnt’ know if those using the 30 day demo version had access to the Gallery Section.
Yes, I can! Thanks, I’ll work on this! :slight_smile:
you were right bd, gallery is available. I was not aware of where I posted it.
sorry
:sweat_smile:
ciao lila anch’io sto cercando di impratichirmi con vray magari ci possiamo sentire per scambiarci qualche idea che dici?
I think you can pm me :slight_smile:
Sorry if I answer in english, but this is supposed to be an english forum :twisted:
