C4D R23 - Corona 7 crashing on startup + Engaging IPR - macOS Big Sur 11.5.2
Not sure what happened but all of a sudden my Corona version 6+7 crashes when I load a file and try to send it to the IPR. I have also uninstalled Corona 7 and tried Corona 6 and its doing the same thing…
Steps:
I open a file that was previously working or any file at this point ( a simple cube and a corona sky)
I engage the Interactive rendering and… Plugin error:
The plugin CoronaCore has crashed.
More information can be found in
‘/Users/username/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/_bugreports/_BugReport.txt’.
I attached the bug report below and some more info/screenshots of my system.
No clue what is happening. Any help would be greatly appreciated. Thank you!
_BugReport.txt (886 KB)
thanks for reporting. Please try the following.
For Mac: go to /Library/Application Support/Corona/ and delete the LicensingLog.txt (Library is the user one)
Let me know if this helps.
Thanks,
Jan
Hi Jan,
Thank you for your help. I have tried what you have suggested and still no luck. Opening the same file crashes c4d immediately.
_BugReport.txt (998 KB)
could you please share the scene with me?
Thanks,
Jan
Do you have Redshift installed?
Not on this machine.
Hi Jan,
As it turns out it looks like its now working again some how… I am guessing it was some sort of odd bug in the activation key or something but everything is now working again once I reset the activation for corona via my log in information. So as of now… I think we are good. Many thanks for your help!
