Hello, is there a way to use calibrated to cd/m2 HDRI maps correctly?
Here is the example, how I can do it in Mental ray. (See attached hdri map)
Sky_Cloudy_Free_Env_calibrated.hdr (325 KB)
corona interprets the input as W/m2/sr
1cd/m2 = 1 lumen/m2/sr
lm = W/ (lumen per watt)
How many lumens in 1 watt?
it is not that simple and I dont have time to study details now.. but try multiplying or dividign with 683
It depends on the efficiency of the lamp. But beacuse its already calibrated, i would asume there is no “loss” in the transformation cause its not a “ligth bulb” just a measure of that ligth.
So in this case efficiency would be 100%, and therefore are equivalent.
Check this:
I don’t quite understand you, but I have already found Luminous efficacy - Wikipedia -
source | Luminous efficacy of radiation (lm/W) | Luminous efficiency
Ideal monochromatic 555 nm | 683 | 100%
Ideal monochromatic 507 nm | 1699 lm/W[12] or 1700 lm/W[13] | 100%
I was saying that conversion from W to Lumen depends on the “eficiency” of that energy conversión in the real world.
The ideal monochromatic 555 nm source has a Luminous efficacy of 683 lm/W with respect to máximum response of the human eye means something as for each watt applied to the ideal ligth source (some kind of green laser ligth i guess) they produces an output of 683 lumens at 100% eficiency (respect to the response of a human eye).
But for an hdri the encodes ligth in form of a number (a measured number) there is no efficiency involved cause you just have that measured ligth straight away. There is no Watt input to a lamp to see how much that lamp disipates in other forms than visible ligth so you can have a W to Lumen ratio and cause HDRI’s are linear encoded in nature i would asume that units are equivalent.
