Last night I had a scene I was submitting for rendering that had a vray dome light as the only source of illumination. Every render I got back it was like the dome light wasn’t active at all. I was pulling my hair out until I turned off motion blur on the physical camera and it worked fine after all. Is this a known issue and is there a workaround for it? Every time I submitted it to Chaos Cloud, I got the warning that it needed to be Active View, instead of picking the camera due to having motion blur, so I selected Active View, could that have caused the issue?
Hi, thanks for posting.
I tested a simple scene using a VRayDomeLight and VRayPhysicalCamera with motion blur but it was exported to Cloud and rendered without any issues.
I did a V-Ray CPU test. What are you using GPU or CPU and what are your versions and host platform (3ds Max)?
There is an older report in our system about an issue using a Dome light with Gradient Ramp and VRayPhysicalCamera with MotionBlur. The render is black so this sounds very similar to yours.
Please open a ticket to support and include a link to this thread as well as your job ID in the description for further investigation.
Appreciate the quick response! I’m on 3ds Max 2024. It’s also not a VrayPhysicalCamera, it’s just the Max Physical Camera. I was using CPU, most up to date version of Vray for Max2024. I did submit a ticket already.
Hi, we will need to review the scene to provide better support. I checked the ticket progress and I see that one of our specialists has already answered you. Please follow her advice and in case you need more advice please update the forum thread here as well.
