I want to create a Camera path in enscape in order to export a video.
I set the start position of the path, I make a round of the building and after I set the Stop position.
When I see the video, the path goes from the start point to the stop but from the opposite direction. So the video is too short and it doesn’t show the part that I want.
I have the same problem when using the ‘Move’ tools go inside to the building. When I create the path I avoid to go through in the walls. But after, when I see the video it is just go from the start point to the stop point without consider the path that I indicated.
first of all - which Enscape version do you use? We’ve introduced keyframes instead of start/stop positions for the video path in the past release.
With the new video editor you can set multiple keyframes, view the camera path on the scene and change/add/remove keyframes if needed. The path is not recorded directly from your navigation - you have to explicitly set keyframes (via GUI or by pressing ‘K’) to build a camera path.
@Marts the most recent preview version is on the end of the page. Note that these are the preview versions which may not be stable, but include the most recent features and bugfixes. You can find latest stable release version 2.2.3 on the regular download page.
Thank you for your time., I downloaded this version [ I have Revit 2018]
Version: 2.2.2.259-gdd0e93a [link removed]
Released: 2018-04-10T09:21:03.5980888Z
Changelog:
Revit: Faster material edit workflow
Continuous video recorder improvements
Less noise during walkthroughs
But when I open the enscape plug - in and I go to ‘About’ Tab I still have the version 2.1 for the enscape and the version 1.0 for the enscape plug-in.
@Marts are you sure that you have uninstalled the previous version correctly and installed in the same place. We have seen this behaviour when you have installed 2.1 for all users, and then installed 2.2 only for the current user. The CAD software then does not know which one to use.
Please could you tell me how video capture works on enscape 2.2? I was user of previous versions and i knew how, but now i don’t see same buttons…please need your help
