Cannot use ACEScg Workflow Setup
we are currently using an ACES workflow for our renders.
following this guide closely: V-Ray for 3ds Max
The OCIO Setup is loaded through a file (not env. variables) but when rendering in the cloud we seem to only get SRGB results in the final renders.
The same setup locally produces fine results.
Additional Info: We are always using the effects results image
This has been reported into our bug-tracker as CLOUD-1580 and we will notify you when we have any progress.
I’m sorry for the slow reply. Can you please send me a link to the Chaos Cloud job? The link holds the job ID which we can use to locate the job in our admin and investigate further. Though currently we have an issue for OCIO config files - they are not applied in Chaos Cloud. So most probably this is the issue. Nevertheless please share the job with me (you can do so in a direct message in the forum).
Thanks,
Vladie
hi,
this would be an example job id: https://cloud.chaos.com/jobs/FkNshQhUXm\_qPpYl
Thanks for sharing! But as my colleague Viktoria has correctly said, it is an issue that we have to fix and it’s logged. We’ll follow up with you once we have more on this.
Bests,
Vladie
Hi, are there any updates or timeline on this issue?
Still no timeline but it’s in the short-term roadmap list and we’ll prioritize it accordingly. We’ll keep you updated.
Vladie
Hi. I’m looking for a solution to this as well.
ACES would be great with OCIO workflow.
The OCIO support was recently added along with the latest Client App 1.15.0 released version. Feel free to download it from here.
