In the rendering section of phoenix, the rendering mode options (implicit surface,Geometry atmosphere and Heathaze) are not available to me. vray is working fine. thanks for any help.
perhaps your build is for scanline, see the name of the installation archive, it contains vray or scanline. another issue that you will hit is that rendering with vray the smoke will appear black unless there is geometry behind it.
hah! you sir, are magnificent. thankyou
