Sometimes when I want to composite a hidden line version of my renders with the normal output i use the following technique :
- I render my image as I do normally
- Then I select all of the objects in the scene and make them matte (through vray properties)
- Then I assign a vraytoon effect to the environment
- I make the environment background in max White
- I also turn vray environment to White
This way I get a nice hidden line render with fully black lines on a pure white background wich I can easily composite using a multiply blending in photoshop.
This always worked for me until today : as you can see on the attached image the background is white indeed, but everything behind the objects is dark grey. Am I doing something wrong here or what ?
