Hi.
Just downloaded the brand new 1.7 but Material Library doesn’t load no more. Material library was working fine with RC10.
Doing a custom installation of 1.7, material library doesn’t install no more because it appears already installed (and it is).
Tried also to install it manually from dropbox folder, but i’m not sure if the path was correct (C:\Program Files\Corona\materials\ ???).
Ok, guys. Just uninstalled the RC10 and then installed the new one and now it works correctly.
Installing 1.7 above RC10 brokes the link to Corona Mat Lib (3dsmax2018+W10 Pro).
Please try the following:
-uninstall Corona from the programs and features list
-go to disk cleanup in Windows, and clear temporary internet files
-open internet explorer and clean browsing cache
-Go to your X:\Users\yournamehere\AppData\Local\Autodesk\3dsMax\2015 - 64bit\ENU\en-US\plugcfg
and remove the CoronaRendererMenus.ini file. You may also remove anything else with “Corona” in it if you wish.
-In 3ds Max run customize > customize user interface > menus tab > menus at bottom-left > find Corona and delete it (if it’s there)
-Install Corona again
Let me know if that helps or not.
The library is installed into C:\Program Files\Corona\materials
It worked just uninstalling RC10 with Corona Remover and then installing again the final release.
It downloaded again the Mat Lib and then everything worked.
