cant start max 2011 with sp5
After installing vray sp5 at work I´ve got the dll errors while starting max 2011 !
The first error is " vrender2011.dlr failed to initialize" an then I got several dlo issues…the models could not be found.
Uninstalling and new installing vray and max was no solution and the Vray plugins line in the plugin.ini is the last one. :frowning:
vistax64
Jon
There are two plugin.ini files; one is in the root folder of 3ds Max, the other is in your local user settings (c:\users\… on Windows Vista/7 and c:\documents and settings\… on Windows XP); make sure the “Additional V-Ray plugins” folder is the last one in all of them.
Additional MAX plug-ins=C:\Program Files\Autodesk\3ds Max 2011\PlugIns
this is the ini from local user. There are no vray plugins like in the ini of the root folder!
maybe I have to copy them over into the other ini?
ini from Root:
mr Arch & Design Viz Shaders=C:\Program Files\Autodesk\3ds Max 2011\help\mr.architectural.shaders.pdf
FBX Plug-in Help=C:\Program Files\Autodesk\3ds Max 2011\help\fbx\index.html
mental ray Reference=C:\Program Files\Autodesk\3ds Max 2011\help\mr_reference.chm
Backburner User’s Guide=C:\Program Files\Autodesk\3ds Max 2011\help\Backburner_User_Guide.pdf
Backburner Installation Guide=C:\Program Files\Autodesk\3ds Max 2011\help\Backburner_Install_Guide.pdf
mr fast subsurface scattering tutorial=C:\Program Files\Autodesk\3ds Max 2011\help\fast_sss_tutorial.pdf
Occlusion tutorial=C:\Program Files\Autodesk\3ds Max 2011\help\occlusion_tutorial.pdf
mr Production Shader Library=C:\Program Files\Autodesk\3ds Max 2011\help\mr.production.shaders.pdf
V-Ray main plug-ins=C:\Program Files\Autodesk\3ds Max 2011\plugins
V-Ray additional plug-ins=C:\Program Files\Autodesk\3ds Max 2011\plugins\vrayplugins
Ok, then; what happens if you remove the line that says ;=;
I get still the same errors.
Jon
Hm, the only thing that I can think of, is to uninstall V-Ray, make sure all relevant files are deleted (vray2011.dll, vrender2011.dlr, the vrayplugins folder), and then re-install it - just in case something has remained from another build.
I´ve reinstalled max and vray now! After that I deletet the files left in de root folder completely and deleted all the vray files. Then I´ve reinstalled everything but i still geht the damn errors!
Hm…my workmate means that maybe there are some Visual C++ files missing, for working with the dlo files. But I´ve installed C++ 2005,08,10,
And normally they are installed with max the first time ! So this may may be a reason ?
:S
Jon
They are installed with 3ds Max, yes. Which version of V-Ray did you have before?
We used 3ds max 2010 with sp4a…now 3ds max 2010 with sp5 and no problems.
But when I want to change to 3ds max 2011 on my workstation I geht this errors with the sp5.
Before the release I used the sp4a (max2010) for a short time with max2011 without the errors!
But it would be great to have the new features of sp5 inside 3ds max 2011.
Ok then; can you try the following:
1) rename the \plugins\vrayplugins folder to something else
2) make sure you have vray2011.dll and libmmd.dll in your 3ds Max root folder (and that they are the ones from the V-Ray installation)
3) make sure that vrender2011.dlr is in the \plugins folder
4) rename the plugin.ini file in the local user folder to plugin.ini.off
5) remove the ;=; line in the plugin.ini from the 3ds Max root folder
If that still does not work, please email me to vlado@chaosgroup.com and we’ll see what else can be done.
I’m having these problems now…
Did everything above, and it nearly worked - but when max started it said it couldnt load the vray sky plugin. So it would work, but i’ve got no vray sky…
Before then nothing to do with vray would load.
Any more ideas?
edit: NEVERMIND! manually removed all vray files and did another re-install, started working. Odd, but whatever.
