This is happening all over the place for my users:
If Max crashes (or sometimes randomly) the next time Max is opened Vray is completely missing. Max complains about missing Vray dll’s. Vray at this point needs to be re-installed.
Any ideas whats causing this and any better ways to fix it rather than re-install?
i don’t know where to fix it with the max9 user profile option turned on, meaning i don’t know where the plugin path information is stored.
…but if you have reverted your max9 user profile option back the pre 9 way, you should be able to modify the plugin.ini file to correctly have it locate vray. the plugin.ini file is stored in the max root directory.
make sure these line is on your plugin.ini file, and make sure they are listed after the standard plugin line…
