heya
Is there any way to disable flakes?
heya
Set the flake colour to black?
Regards,
Thorsten
set the flake density to 0, it’s work ![]()
Can’t be black(what about black metalic?
), but I’ll give a go with density, will it free memory from creating flakes map too?
Sure can be black…with a black metallic paint the FLAKE colour is still not black, as black flakes on black ground would be pretty much invisible ![]()
Setting the color to black removes the flakes definitly. I still wonder why you’d use a carpaintMtl tho when you dont need the flakes ??
Regards,
Thorsten
If you don’t want the flakes then just make a blend material… The whole reason for the CarPaintMtl is having the flakes which help simulate the physical properties of carpaint more accurately.
