Caustic enable issue
hello, i tried to use caustics with cuda, it wasn’t working.
I had to revert to cpu mode fire a render then caustic started, then i could switch back to cuda to have caustics working.
Not sure if it is from my side
Hi @youssef_assi Thank you for sharing.
While Caustics with GPU have some limitations it should work as expected if avoiding them. You can find a list of them HERE
Have you tested the Caustics in a simple scene?
What versions of V-Ray and Houdini are you using? Please share the exact screenshots from the About V-Ray and About ( Houdini ) menus.
Please share a screen-recording showing the issue.
