As for the chaos Scatter limit test, the number of single living plants is 4.5W, and the number is 100W and 500W respectively. At 500W, it is almost impossible to update IPR. Attached is the test document
chaos scatter test.zip (12 MB)
Hi, we are aware of that, and are actively working on performance fixes/improvements.
Thanks,
Jan
Is Chaos Scatter already available? I missed that if it is. Will this replace using Cloners to spread items on a surface? I see it has several smart features as well.
Never mind. Didn’t see there was a new daily build out. A LOT of new stuff! Great news.
Yes, Chaos Scatter performs better than Clone in optimizing geometric memory and Scatter location. As a matter of fact, I used the same model, even with proxy, it was difficult to calculate the number of Clone in millions, which I think is the advantage of Chaos Scatter. It would be a much better tool if fluency problems with large numbers of sctter’s could be solved in the future.
Is there any documentation for Scatter? I can’t find anything.
The 3ds Max tutorials on our YouTube will cover everything but the new features, and get you up and running with how Scatter works. Then the extras like Slope Limitation and Spline Include/Excludes and preserve scaling will all be pretty easy to grasp ![]()
Of course there will be a webinar soon after release, plus new tutorials both for Max and C4D, but the existing Max ones will get you up and running until we have those all ready!
