Hi, I’ve recently upgraded my whole team to max 2023 and corona 9. On 2 of our machines out of 30, Chaos Scatter just will not install no matter what I do. It doesnt appear in the plugins folder but it is in the appdata folder for some reason.
When I unpack the installer and copy the chaos scatter files into the right locations it comes up saying the plugin was unable to start.
My machine is one of the newest and is quite high spec so theres no reason that I can think of for it to not work.
I’ve sorted it thanks. I only copied the stuff for the autodesk folder and not the chaos group folder! I’ve still got no idea why it won’t install automatically like every other machine but I’ll worry about that next time I update.
We’ve isolated one issue with the scatter installer and are working on a fix for it. I’m actively trying to find out if we have another issue..
There is indeed, you can select the unpack option in the Corona installer and there is a readme which explains exactly where to place the scatter files.
If you have more issues/questions please contact our support team on this and they’ll be able to help you out
I run into this crap every time. And never remember what I did to make it work last time. So for future generations..
This time it worked after manually copying scatter files:
from (unpacked): …\ApplicationPlugins\ChaosScatter3dsMax2024
to: C:\Program Files\Chaos\Scatter\3ds Max 2024
Which seems to be diferent location than suggested by instructions on chaos website
Which version of Corona are you using? In version 11 or newer and 3ds Max 2024, the Scatter plugin files should go into ApplicationPlugins. Not sure why it could be different for you.
