I installed corona 8, but it does not install scatter even using unpaking
Hello there
Please try below solution in order to fix it:
as the first steps, please try:
- Temporarily disabling any antivirus you are using and then
- Make sure that you are not running the Corona 8 installer from a network location. Simply copy it into a local folder (for example C: drive) and then run it.
If the above solution does not help:
I am attaching to this message the Chaos Scatter files for Corona 8 that you would normally see after using the unpack option in the Corona 8 installer.
Please try installing Chaos Scatter manually:
Install Corona 8 using the standard installation method (start the installer, select the standard installation option, proceed as usual)
Unpack the archive I sent to you, go to the resulting folder and then navigate to Chaos Corona\Chaos Group\
Copy the whole “Scatter” folder into C:\Program Files\Chaos Group (so the resulting path will be C:\Program Files\Chaos Group\Scatter)
In the folder I sent to you, navigate to \Chaos Corona\Autodesk
Go into the folder with the name of your 3ds Max version (e.g. if you are using 3ds Max 2022 go to the folder \Chaos Corona\Autodesk\3ds Max 2022)
Copy the content of this folder (“plugins” and “UI_ln” folders)
Go to your 3ds Max installation folder (e.g. in case of 3ds Max 2022 the default folder is C:\Program Files\Autodesk\3ds Max 2022)
Paste the folders “plugins” and “UI_ln” into your 3ds Max folder (so the “plugins” and “UI_ln” have to be pasted into C:\Program Files\Autodesk\3ds Max 2022)
Here is the archived Corona 8 Chaos Scatter installation folder:
ftp.chaosgroup.com/Download/Corona8ChaosScatterPacked.zip
Looks like i’m having this issue with the latest daily…
Any advice? Same process? I don’t see the scatter folder…
Thanks for any much needed help!
Nevermind, got it working from your previous instructions, thanks!
Any idea why/how this happens? And how to avoid it happening?
Would it be possible to get a download package for corona 9 as well? I have a student who’s stuck because Corona 9 won’t install Scatter properly on her computer.
Here is the unpacked Corona 9 archive, without the material library, but with Scatter: https://drive.google.com/file/d/1PTeUxgP_ajWYzIPGzWmCyaCtvumJKlbW/view?usp=sharing
There is a readme file which explains where to put each file. If you need some further assistance, please let us know!
